Seems it’s the breakout board - I bought a cheap one + new drivers - Am having trouble wiring it however there is life, spindle comes on when powered (can’t turn off, can control the speed via the inverter and that’s it and z axis moves up (both keys make it go up), the limit switches are now showing in the diagnostics page and if I home the machine it seems to move in all directions - Estop switch is broken and Will be replacing and the estop button in Mach3 doesn’t stop it - so I quickly pulled the power shortly after it started moving, but seems like it moved in all directions.
How I wired it
