    You said it all when mentioning the grade. Nobody can tell you what to use without knowing the grade and even then with small cutters, the machine stiffness becomes a large factor.
    Unfortunately, it's going to be trial and error. If your machine is stiff enough and the spindle is ok on the runout plus spins fast enough then I can't see why 0.3mm shouldn't be possible with good cooling.
    Thanks Jazz. Yeah was hoping someone would confirm what I thought. I'm running the spindle at 24000rpm with a more precise collet because of the smaller end mill. Flute length could be shorter but I'm working with what I have. Flooding it with paraffin ��
    Quote Originally Posted by Nealieboyee View Post
    Ye, sometimes you just got to be patient and accept it's a slow job. Or you go for it and risk a cutter or two. Me personally if it's just a one-off job then I'd air on the side of caution so don't break cutter but if it's a job I'm going to do regularly then I'd sacrifice a few cutters to find the optimum cutting parameters. It's pays back long term.
  1. solidoworks tapped thread depth and blind hole depth
    By reefy86 in forum CAD & CAM Software
    Last Post: 10-11-2015, 04:14 PM
  2. RFQ: Aluminium parts for mill conversion
    By Ross77 in forum Projects, Jobs & Requests
    Last Post: 06-01-2015, 12:24 AM
  3. Replies: 0
    Last Post: 05-12-2013, 07:28 PM
  4. RFQ: Aluminium parts for my first cnc mill.
    By everyreasonto in forum Projects, Jobs & Requests
    Last Post: 17-07-2011, 11:36 PM
  5. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
