09-02-2020 #8
You do realize that OA is just bullshit for high helix. All cutters are open architecture.!!
The reason you clagged up was melting because was rubbing rather than cutting because the feed rate was too low. At the lower rpm your not rubbing as much but you still rubbing to some degree which is causing excess wear and a poor finish. It's a common mistake to think melting is because going too fast when it's actually the opposite.
Unfortunately with small tools it's a fine balance between too slow and too fast causing high tool pressure which is what snaps tools. Throw shity material into the mix with it's hard and soft spots plus a slightly wobbly machine and it soon becomes a cluster F'@'K..
Chatter is another problem where going faster can actually reduce chatter by increasing tool pressure which pushes the tool into material harder so reduces chatter. The trick is not overdoing it and lowering the RPM.
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
RFQ: Aluminium parts for mill conversion
By Ross77 in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-01-2015, 12:24 AM -
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
RFQ: Aluminium parts for my first cnc mill.
By everyreasonto in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-07-2011, 11:36 PM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
