Thread: Worn leadscrew?
07-03-2020 #2
07-03-2020 #3
Absolutely and very probably is due exactly to that reason. Or they are really cheap nasty rails and poorly aligned.? I've never had a rail wear out to that degree and I've probably got 100+ machines out in the field using them and many of them used 12hr 6Dwk with minimal maintenance with several over 10yr old so if quality rails like Hi-win then I'd definitely be looking for some other issue causing this.
07-03-2020 #4
Doddy: rails had 0.03mm error on 700mm
WANTED: Damaged/old/worn vmc wanted
By Westmach in forum Items WantedReplies: 1Last Post: 05-05-2018, 05:47 PM -
er32 spindle thread worn out anything i can do?
By Lloydm in forum General DiscussionReplies: 2Last Post: 01-08-2016, 10:32 PM -
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Leadscrew
By fusionkid in forum Lead Screws, Nuts & SupportsReplies: 23Last Post: 27-03-2011, 11:07 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
