Thread: NordicCNC's build log
Yes, the pulley sizes in the pictures are 20T and 40T. How many teeth need to be engaged at bare minimum? I have not yet found any supplier (I am trying to find those pulley's with taper lock) so for now during the design phase, I went with some sizes I could find on Ebay.
Skickat från min SM-A530F via Tapatalk
15-03-2020 #2
20T and 40T is good, it's exactly what I use on one axis. Another handy calculator.
I had to deal with the same issue: finding clamping type aluminium pulleys, either HTD or GT3. From my researches those are rare beasts.
HTD taper-lock steel pulleys are relatively common, but add way too much inertia to be considered.
I found 2 options:
- CMT pulleys. The best but expensive, about $60 piece.
- Misumi, with separate taper-lock and pulley. Slightly less expensive, about $40.
15-03-2020 #3
Different manufacturers quote different numbers but I think it's roughly 6 teeth before you have to start lowering the HP rating they can handle.
However, your problem will be the smaller pulley size will limit the number of teeth based on it's Boss size and Motor shaft relationship. 20T / 40T sounds about right with a 14mm motor shaft, if it's 19mm shaft then you may have problems.!
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
