    You say "on the Network" are you trying to run this over a network ie: thru a switch or directly from PC to controller.?
    Also are you using a patch cable or just an ordinary network cable because some network cables can be wired differently to others.!
    PC connected to a hub then hub connected to controller, both standard cables nothing else connected and even tried 2 different PCs (I have a crossover ordered to try)
    Quote Originally Posted by ngwagwa View Post
    Try it direct to controller first to elimnate the hub
    Direct connection and no joy, am trying to resolve with CNCdrive support
    Yhey are telling me I need V1.8 or newer utility tool but I can't find it on their website.
  1. Losing steps
    By Edendale in forum General Discussion
    Last Post: 06-03-2020, 10:10 PM
  2. Weird noise on travel and losing position
    By ngwagwa in forum Artsoft Mach (3 & 4)
    Last Post: 07-02-2020, 05:45 PM
  3. Router losing steps. Solution needed. Will this help?
    By cncbobuk in forum Chinese Machines
    Last Post: 27-12-2017, 03:40 AM
  4. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 10:49 AM
  5. New Mill losing steps
    By lukecnc2012 in forum Gantry/Router Machines & Building
    Last Post: 08-11-2014, 02:56 PM
