25-04-2020 #9
Have my AXBB-E on its way now, so almost all the components - except for the VFD and spindle which I'll leave until I have a moving machine .
I'll be trying to get UCCNC to control one motor so I at least know it can be done (by me:) ) Linking it up to the Laptop is probably the only part of the electronics I hope goes easily with IT background..!
So I'm planning to use CAT6 cable I have already for STEP/DIR - do I just use the individual cores still twisted and leave in shielding for the run to stepper?
Also - what's the best method to join the fixed motor wiring /limit switches to CY cable - just solder and heat shrink over the top? if the CY doesn't run right to the motor (only 1/3 or so) is there any point grounding the shield at cabinet end?
600 x 400 Aluminium Profile Gantry Router
By Journeyman in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-03-2016, 04:28 PM -
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM
