Thread: Rotating Ballnut - design ideas
28-04-2020 #2
I agree with Boyan and we Both have experience of using rotating ballnut design, so you might want to listen. That design and those bearings are not good for this application because of things which have been stated. They will work ok, but they won't last ok, the forces are in all the wrong places so between this and the heat generated because these ballnuts are being run in ways they where not designed to run it will impact the life and performance.
But you could say what do we know.? In which case go for it.!
There are currently 12 users browsing this thread. (0 members and 12 guests)
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
