30-05-2020 #10
I'm looking for some recommendations on bed materials, machine will mainly be used for aluminium and composites, so preferably something that can take coolant. My last machine used epoxy soaked MDF which was far from ideal. The plate would need to be 800x1300.
I don't have a large enough piece of aluminium plate. So options I'm looking at are:
1. 20mm Tufnol, can't find this in sheets longer than 1200 so would have to alter the frame, this isn't really a problem. I'm not sure whether this is rigid enough to span the cross beams that are on 400mm centres??
2. Purchase a piece of 20mm aluminium plate large enough, quiet expensive.
3. Locate some aluminium extrusion T-slot bed profile 'planks', I can't find these either.
Thoughts?
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
