Page 9 of 23 FirstFirst ... 789101119 ... LastLast
  1. #81
    Progress update!
    I got back to the project after a break of a few months to work on other things. I ended up pouring epoxy to bring the X rails into plane, then set the master rail straight using a taut wire, microscope and some software as described here:
    http://www.mycncuk.com/threads/12966...r-level/page27
    I now have both rails mounted and the gantry moves very smoothly.
    Next step is to fabricate the motor brackets and mount the ballscrews and steppers. I've ordered belts and pulleys and am waiting on these so in the meantime I started to fabricate a stand for the machine. Since the machine is itself a rigid structure this stand only serves to anchor it to the floor at a decent working height, hence the lack of bracing. All 4 legs will be bolted to the concrete floor then the machine will sit ontop on leveling bolts, finally the machine frame will be clamped hard to the stand so that it doesn't throw itself across the room (voice of experience...).
    Cut and welded yesterday, painting in silver hammerite today. The more I use it the more I love this little MMA stick welder. welded the 3mm box section mitres at only 45amps! Almost as good as a MIG without any complications.
Name:	IMG_20200528_195623_1 (Large).jpg
ID:	28237 Click image for larger version.
Name:	IMG_20200529_115806 (Large).jpg
ID:	28238 Click image for larger version.
Name:	IMG_20200529_123836 (Large).jpg
  2. #82
    I'm looking for some recommendations on bed materials, machine will mainly be used for aluminium and composites, so preferably something that can take coolant. My last machine used epoxy soaked MDF which was far from ideal. The plate would need to be 800x1300.
    I don't have a large enough piece of aluminium plate. So options I'm looking at are:
    1. 20mm Tufnol, can't find this in sheets longer than 1200 so would have to alter the frame, this isn't really a problem. I'm not sure whether this is rigid enough to span the cross beams that are on 400mm centres??
    2. Purchase a piece of 20mm aluminium plate large enough, quiet expensive.
    3. Locate some aluminium extrusion T-slot bed profile 'planks', I can't find these either.
    Thoughts?
  3. #83
    Quote Originally Posted by devmonkey View Post
    Thoughts?
    A bit more research on different materials, Young's modulus (GPa):
    MDF 4
    SRBP (paxolin/tufnol) 6.5
    Aluminium 69
    Steel 200
    The deflection of a rectangular section spanning two supports due to a downward force in the middle is inversely proportional to the Young's modulus * thickness^3.
    So taking 16mm aluminium plate as a reference, thickness required for equivalent rigidity of those materials are:
    MDF 41mm, SRBP 35mm.
    Or another way, 25mm SRBP is equivalent to 12mm aluminium.
    From this it is probably ok to conclude 25mm SRBP supported on 4 sides over rectangular bays in the machine frame that are 840x320mm is probably sufficient.
  4. #84
    MDF 4
    Aluminium 69
    Steel 200
    I would probably use one large piece as the bed, then a second piece as the sacrificial board.
  5. #85
    30mm HDPE makes a nice stable bed and you can cut a grid pattern to make it into a Vacuum bed. I bought a 10x5 sheet for £500 so if you get in touch with plastics supplier you might get a small piece or cutoff piece cheap enough.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  6. #86
    Ok thanks, that is interesting, YM of HDPE is only 0.8, how much support did you have under it, or what was the clear span? I guess we are only talking about supporting the mass of the part being machined and the downward force of the cutter, this is probably minimal, like to take a punt on what this force is?
    Looks like an 8x4 sheet of 25mm SRBP is £380, this would give me enough for the base board and two spoil boards.
  7. #87
    Stand levelled on floor and machine craned ontop to check final position, needs to be moved out from the wall a bit so I can fit/service the ballscrews motors. Starting to look like a CNC machine!
Name:	IMG_20200530_124355 (Large).jpg
  8. #88
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    Looks seriously serious! Make sure you have enough room to move around it while bending over and enough room to fit a screwdriver in all the places you didn't think you'd need to fit a screwdriver when you first thought "I'll put it here!".
  9. #89
    Finished making the last set of plates, these are for the X and Y axis, ballscrew mounting. Hopefully this is the last of the aluminium work on the manual mill. I still need to make some stepper mounting plates but leaning towards doing those in 3mm steel.The white parts are 3D printed standoffs for the X axis ballnut holders, I didn't have any large enough ally stock so we will have to see how they fare. They get clamped between two aluminium lumps so should be ok, if not will replace when I have some bar stock.
Name:	IMG_20200531_154645 (Large).jpg
ID:	28250 Click image for larger version.
Name:	IMG_20200531_154654 (Large).jpg
  10. #90
    Any they all fit:
Name:	IMG_20200531_161956 (Large).jpg
ID:	28252 Click image for larger version.
Name:	IMG_20200531_163616 (Large).jpg
ID:	28253 Click image for larger version.
Name:	IMG_20200531_164256 (Large).jpg
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
