Thread: eBay router
Hi Dean
I put a post up in reply to one of your posts regarding this a few days ago, but I don't know if you have seen it.
I want a CNC router, say 1000 x1000 or preferably half 4x8 ft sheet so that in two steps, I could route/mill a 4x8 foot sheet when needed
If I did want to build one myself with the main purpose of routing aluminium sheets and milling alumium parts, what would your suggestions be for me to build one ? Ie are there any plans out there that you would recommend to base my build on ? I do have access to a manual mill and lathe (Warco ones)
Alternatively, I noted in one of your posts that you also build machines. Would would it cost for you to build me such a fit for purpose machine ?
Many thanks
23-07-2020 #2
No sorry didn't see it but I am very busy so only skimming forum every other day so must missed it.
Well, this is the issue, profile cutting thin (2-3mm) aluminum sheet isn't that taxing provided your using correct tools and feeds which is why these weaker machines can do that. However, cutting or milling thicker parts with a good rate of material removal with good finish quality and accuracy is a completely different story and requires a very sturdy machine which is why I know these machines cannot handle it or do a very good job.
As the machine gets larger then it gets even harder so really you need to decide what's most important to you, sheet cutting, or milling.? Because two very different machines are required. Large machines don't lend them selfs to milling aluminum very well unless heavily built so be prepared for it to cost more money.
Search the forum is my advise and look at machines with high sides and gantry sat directly on the rails. Boyan built a massively strong machine which is IMO OTT for most things but will happily Mill aluminum and steel to a lower level.
I don't know of any plans that are any good.!
The question I would ask your self is do you really need to MILL large aluminum parts that won't fit on a smaller machine which is much easier and cheaper to build. One machine that can do it all and to a good standard is very difficult to achieve and not cheap.
If you are serious about me building a machine then contact me directly via PM giving me some idea of your budget and I'll see what I can offer you.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
24-07-2020 #3
Hi Dean ..
You are right in that CNC routing and CNC milling are two different things, though they do overlap a certain amount.
I am probabbly being too generic in my requirements.
I have a requirement to mill thicker aluminium such as 25mm or thicker but not at 1000mm x 1000mm, but probably not more than 400 mm x 400 mm.
I do have a requirement to route other materials like wood, ply, perspex, etc... at around a half 4ft x 8ft sheet so that I could do a full 4ft x 8ft sheet in two separate operations.
I suppose I really should be looking at two machines for that rather than one machine to do it all
I do have a warco WM16 manual mill that I am looking to convert to CNC but the throat size (as with most mills of that gender) is limited to about 140mm and with a bit of clever work with spinning the part around 180 degrees one could cut the part in two operations and perhaps achieve a part of up to around 250mm width which falls short of my ideal 400mm.
What are your thoughts about which direction I should really be looking at to solve my requirements
Many thanks Dean
1300x 1300 router with vac bed on Ebay
By Clive S in forum General DiscussionReplies: 0Last Post: 30-01-2018, 03:57 PM -
ebay con
By macca in forum Marketplace DiscussionReplies: 20Last Post: 08-08-2014, 12:43 PM -
Ebay purchase of RECORD SCM 120 router
By GEOFFREY in forum Machine DiscussionReplies: 6Last Post: 06-07-2013, 06:07 PM -
Anyone ever bought a Router from China? (not ebay ones)
By sly666 in forum Marketplace DiscussionReplies: 4Last Post: 03-11-2012, 10:45 AM -
BUILD LOG: ebay score dwt cnc router
By j4son in forum DIY Router Build LogsReplies: 12Last Post: 13-02-2010, 04:11 PM
