    Neale,
    I'm not going to argue with a word of this, and I am coming at it from a wood-working gantry router perspective which is different to a mill. Like you I often reposition the work coordinate zero to suit the job but this will be a known position relative to the homed (0,0) position so that it can easily be re-acquired after an E-stop or other driver-disabling event.
    Kit, you don't need to position the work to a known MACHINE location to get back to WORK ZERO that is the point of the G54, G55,etc WORK OFFSETS and using HOME switches. If you get lost or crash the machine you simply HOME the machine and it uses the WORK OFFSET to get back to WORK ZERO.
    The only thing you may need to do is save the WORK OFFSET before starting the job just in case power goes off mid job. However some controllers save the WORKOFFSET before the start of the job, I think Linux does this and UCCNC but Mach3 doesn't which is a pain as it's easy to forget.
    Regards Backing off the HOME switch then the only point to me, other than to relocate MACHINE ZERO position is to stop potential false trips if using same switch has limits combined with homing or to square a dual motor gantry.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    A precise and detailed description of my own machine!
    I love threads like this, I always learn a great deal myself and as I discovered when I took up teaching technical stuff to adults back in the 80s, there's nothing will show up the holes in your own knowledge more effectively (brutally at times!) than trying to explain things to someone else. I now need to swot up on the full details of G54, G55 and other relevant codes and exactly how LinuxCNC uses and saves them.
    The difference between machine coordinates and work coordinates is, as Neale pointed out, a confusing one tro begin with but soon becomes one of those fundamental bits of knowledge you don't realise you never knew.
    Yes this confuses many people. Have you noticed that you can see the machine coordinates and the current G54,55 etc on some GUIs at the same time. In Linuxcnc you can turn them on and off from the view tab.
    Ie. If you have touched off your part ie X0,Y0 in G54 you will see the machine G53 at the same time completely different.
    http://linuxcnc.org/docs/2.8/html/gc...es/offsets.png
    http://linuxcnc.org/docs/2.8/html/gc...ordinates.html
    Probably without knowing it you and many others have actually been using a WORK OFFSET in fact if you have been using 2. These being G53 and G54.
    When you HOME your setting G53 ZERO which is MACHINE coordinate system and when you set WORK ZERO you're using G54 WORK OFFSET. Almost all controllers, Mach3, UCCNC, LinuxCnc, even industrial-grade controllers like Fanuc, etc use G54 by default and unless you specifically need to use a different OFFSET say for things like multiple vises with OP1 OP2 type setup or several Fixture Jigs which all have a ZERO point you don't need to know about them.
    Most CAM packages are also set up to use G54 by default which is another reason why many users don't actually know they are using WORK OFFSETS.
    If you have a large working area WORK OFFSETS makes cutting several different jobs say as in different materials or thickness very easy because of each Fixture as it's own ZERO.
  1. mach3 soft limits
    By Daveo in forum Control Hardware & Systems
    Last Post: 25-06-2020, 05:24 PM
  2. Lichuan "Easy Servo" closed loop stepper question
    By Voicecoil in forum Stepper & Servo Motors
    Last Post: 09-10-2019, 09:33 PM
  3. "Hacking" and "Modding"
  4. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  5. "Racks" VS "ball screw"
