Thread: Boxford v190 cnc
Crazy high = ??, out of curiosity.
19-10-2020 #2
You should be looking for < 40,000
On a lathe a CV little higher will not hurt
You are running the same HP pc as I will be using (yes). If so then the max jitter is really quite low
Can likely be improved with an external graphics card as linuxcnc is not recommended with onboard graphics which share system ram
But having said that I’m getting quite low max jitter readings anyway so I think all will be ok
It’s an option from the linuxcnc menus to run test max jitter
Set it running then abuse the pc as best you can and come back to the results after about 10 mins and use the result displayed in your linuxcnc config
What it actually does is inform linuxcnc how much resource is available to process things. When it runs out it would be bad so it limits movement speed to a slower love per second to fit within the available resources
You are not going to hit this on a small lathe as first only two axis are being moved at any time and secondly the steppers are not micro stepping down to really low values. I think I run mine at 4 micro steps which means one Rev of motor (4mm true movement) is a total of 800 pulses
You can imagine as the micro stepping is increased, some run 64 micro steps, that the number of step direction pulses increase very quickly for the same amount of physical movement
Then
Multiply this by three axis movement potentially all at the same time on a mill and you can see that pc resources are a lot more critical on a mill than a lathe
Paul
FOR SALE: Boxford MT2 & Boxford TCL125
By jonnydeen in forum Items For SaleReplies: 3Last Post: 12-11-2021, 11:24 AM -
New Spindle drive Boxford V190 VMC
By mosoeng in forum Boxford Vertical MillsReplies: 4Last Post: 19-09-2019, 09:11 AM -
SOLD: Boxford 260 VMC
By Woodfish in forum Items For SaleReplies: 6Last Post: 11-12-2018, 08:34 PM -
FOR SALE: Boxford 160tcl Lathe and 260 vmc milling machine with full boxford software for sale
By Waine in forum Items For SaleReplies: 2Last Post: 21-04-2016, 09:18 AM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM
