Page 17 of 22 FirstFirst ... 71516171819 ... LastLast
  1. #161
    Ok sounds good - let me see what I can do about the CAD model to help you out.
    Quote Originally Posted by fer662 View Post
    Oh, so you essentially welded the sides, then assembled the table with screws and taps, and then welded it together? was it mostly to prevent it from moving?
    What about the legs, did you solder anything below the open 80x80 tubes? I cannot bolt the table down to the floor because i have floor hitting and i'm sure i'll be unlucky enough to hit a hose with the drill. Probably won't be necessary as the table will weight a shit ton.
    Looking back over the photos in my thread, I can see why you thought it was just bolted. As it was my first time welding, I wasn't at all happy with how the process was going - I thought the welds were coming out pretty ugly and I had a number of "retries" grinding out bits that felt crappy and weak and doing them over again. As a result, I just didn't take many photos of the build during this stage, I was quite disheartened with it. It wasn't until I had something I was happy with (after lots of grinding, welding, regrinding, smoothing with some filler, sanding, then finally painting that I started taking photos of the frame again.
    Lets start back here - October 2018, all the frame steels (bar one!) were cleaned up, tapped, bolted together into an assembly I was happy with.
    I then turned the frame over, and started welding the caps on the bottom of the square tubing for the feet. I'd drilled and tapped these prior - but in hindsight I'd have welded a nut on the inside first to give more thickness to the thread. It was at this point I set my crotch on fire. ;)
ID:	29096 Click image for larger version.
ID:	29094 Click image for larger version.
ID:	29095 Click image for larger version.
Name:	leg120190106_144402 - Copy.jpg
ID:	29097 Click image for larger version.
Name:	leg220190106_144412 - Copy.jpg
ID:	29098 Click image for larger version.
Name:	leg320190106_144407 - Copy.jpg
ID:	29099 Click image for larger version.
Name:	leg420190106_144419 - Copy.jpg
    By the end of the day I was quite happy with how it was sitting on its new feet. I'd also started preparing the steels for the adjustable height bed.
Name:	20190106_163037 - Copy.jpg
    Then I started to tack weld the joints together all the way around, being sure to do one tack, then move around the machine to try and reduce distortion. Once that was done, I came back to each one in turn and gave it a full bead. Rinse and repeat.
    I was so unhappy with it I literally don't have a picture of the frame until it was painted.... and even then I wasn't happy with the brush marks in the first coat, so that took a while to sort out!
Name:	20190411_204338 - Copy.jpg
ID:	29102 Click image for larger version.
Name:	20190627_194412 - Copy.jpg
  2. #162
    Andy,
    That's a very informative and encouraging set of photographs. And a dire warning re starting fires in awkward places! I'll be reassembling my own machine in it's new home before long and a new welded base is going to be a major upgrade.
    If I can produce something that looks that good (even with brush marks in the paint) I'll be well pleased.
    Kit
  3. The Following User Says Thank You to Kitwn For This Useful Post:
  4. #163
    Thing is, now I'm using it, I've scratched and chipped the paintwork a number of times. I think I've given up trying to be precious! Still functional after all.... ;)
  5. #164
    With the machines I build looks plays a small part, mostly to help with the appeal to new users who tend to buy on looks rather than functionality. then I can educate them on what's required for good machine.
    On my own personal machines I have absolutely zero interest on how they look, infact, they look SOOOOO bad with wires and crap hanging off them from product testing or failed tests or just plain lazyness regards cleaning, (No lets be honest I've never cleaned it, occasional blow job if it;s lucky.) I wouldn't dream of ever showing them to anyone because if I did no one would ever buy a machine off me again...
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  7. #165
    These are going to be really useful. I appreciated it! I'll post my table on my own thread whenever I have time to start it.
  8. #166
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    One of the most interesting things to do is have a look round someone else's workshop. One of the most embarrassing things is to show someone round your own...
    As for paint - wossat? They don't have to look pretty to do a useful job.
  9. #167
    Notice how the garage started off relatively empty, but quickly gets fuller and messier throughout the photos? Its only gotten worse.....
  10. #168
    I've been hard at work with the CAD! Could I bother you for some measurements? Could you tell me how far apart you have the linear bearings for the same rail on each of the axis... Say.. Measuring from the outside of the blocks? (and if you're happy with the resulting rigidity)? It's the one area where I don't want to simply overdo it since you lose work area.
  11. #169
    It's interesting to see how much effort different people put into making the parts of their machines look good. There's even one in the archive with beautiful red anodised parts that I would have just filed the sharp edges off and left at that.
    For a professionally made product there is always the element of customer confidence. If the surface finish is poor how much care and attention did the manufacturer take over the bits that DO matter?
  12. #170
    I mean... Most of us end up spending way more than it'd have cost to just buy the machine done... It's a matter of pride in what you build at some point, and for some people aesthetics is a part of that.
  2. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  3. BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
    By MikeyC38 in forum DIY Router Build Logs
    Last Post: 16-06-2018, 11:29 PM
  4. Any sugestions how to build my gantry
    By masinecc in forum Gantry/Router Machines & Building
    Last Post: 20-09-2015, 05:17 PM
