    I assume the native units in config is what I must toggle to inches. I assume I have to change all the limits and homing values to imperial too, as well as the parameters under motor tuning. In motor tuning I assume I factor the G’s parameters too - or is this dimensionless?
    Quote Originally Posted by Stressedwoodman View Post
    Yes toggle native untis. If you have Softlimits set then yes they will need changing also.
    You can't change the G's it auto-adjusts with the Velocity and Acceleration changes.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. NEW MEMBER: Hello from Lincoln UK (Converting Warco WM14, need to learn G-Code or CAD CAM)
    By Jools in forum New Member Introductions
    Last Post: 29-11-2020, 03:09 PM
  2. FOR SALE: Oxford 0-25mn Metric/Imperial Digital Micrometer with SPC
    By Caster1 in forum Items For Sale
    Last Post: 03-01-2016, 08:52 AM
  3. Converting Imperial fractions to metric. Solution?
    By ChrisG in forum Machine Discussion
    Last Post: 03-02-2011, 07:11 PM
  4. Conversion Tables TO - FROM Imperial/Metric
    By Lee Roberts in forum Machine Discussion
    Last Post: 27-02-2008, 02:08 PM
