    Hello,
    Please is it at all feasible to convert this sort of a machine to CNC:
    - I bought this King Midas (TFY-515) mill a year ago, with some tools.
    - It is a lovely machine, cuts nice and smooth
    Machine looks like this (though this is not mine):
    http://good-times.webshots.com/photo...74179466IJBgoP
    Problem is a huge slack in Z-axis.
    - One can either use a knob, turning clockwise / anticlockwise (there is a lot of slack, when changing direction, eg. first move down, then move upwards, slack is in changing direction)
    - OR: alternatively use a lever aside. There is not much slack there. (but movement of lever pulley is only some 1/3 of a full turn, so guess one could not attach a motor to it...)
    Attached a couple of photos of my mill. (this is the one which is my own :) )
    Please suggest, where can I go from here?
    - Source another mill?
    - something else ____ ?
ID:	5391   Click image for larger version.
ID:	5392   Click image for larger version.
ID:	5393   Click image for larger version.
ID:	5394   Click image for larger version.
    In a case like this the easiest way would be to clamp a plate around the quill at the bottom and use a ballscrew or similar to push / pull this plate and bracket. The existing pinion would be discarded.
    John S -
    I would have a go at replacing that pinion first made up of some MOD gear and rod or just another one machined?
    Hi. I have a Myford/Rodney mill mounted on a very nice base. This is always a problem with rack and pinion z axis. My Myford drives the rack thought a worm and wheel which is hinged so it can be diss engage. I tighten up the vertical and always approach in from the same direction (very normal on a lead screws). The hand wheels marked in thou, I reckon about 5 accuracy but its a challenge. But it drives the rack via a worm to gear everything down.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
    I agree with John S. If you leave any springs or gears in the Z drive you will come to regret them.
    Best to make the plate detatchable from the screw. That way you can still use the sensitive drill handle and you don't have to hammer against the screw when you dislodge taper tooling.
    Thanks, like this advice, this is what I wanted to hear. For a while thought this is it, need another mill, but now there is some light.
    Had another look at the mill today.
    1) Z-axis (the original question)
    - Do you think it might be best to fit the ball -screw as in picture?
    -- (and yes make attachment -plate detachable from screw)
    - Or perhaps try to hide the screw inside the "tower"?
    - Or attachment to the quill ?
    2) The Z-axis screw is possible to disable. (picture)
    - perhaps one could leave it there, then?
    - or would you take that out altogether?
    3) Noticed, actually there is slack in X/Y -axes,too.
    - So while we are at it, maybe retrofit ball screws, there too?
    - How to choose correct ball-screws?
    -- Length: existing screws + a bit more?
    -- Diameter: similar to existing screws? (does it matter if they are not quite the same?)
    -- Where to go from here? Take the table apart, to measure existing screw? Make a mockup / sketch?
    - View from underneath of my mill (X/Y -table)
    4) X/Y -table drawing / plan of parts to change?
    Would appreciate any comments (no need to answer all questions). Sorry for a long post . Thanks!
    A friend of mine converted his vicroy and here is what he did:
    1.left original screw in the lower knee Z and a powered this (backlash is less of an issue here)
    2.left the spindle Z as manual so at to always keep this up and maintain as much rigidity as possible during milling ops (still had the option to lower if needed)
    3.replaced screws in the X an Y planes with ball screw
    I didn't realize Z-axis backlash is a smaller issue than X/Y -backlash. But it starts to make sense. Thanks for comments!
    Right now, I will try to figure out exactly what to do, by studying other builds.
    Perhaps will then come up with a "shopping list", and can start, and hopefully finish, too, my own CNC conversion thread.
    This CNC -thing is such a fascinating, quite addictive topic Admire you folks a lot.
    Quote Originally Posted by diy-john View Post
    The question is, are you going to become anal about backlash and go for true zero? I know I did. Also retaining the handles and dials on X and Y was a pain but I am ever so glad I did :heehee:
    A man has to ask himself, would I be happy with my circles 15um out due to backlash? It is very nice when digi calipers occasionally measure the finished job as something.00mm
    I'd suggest starting with a crude CNC conversion, get it cutting, identify the problem areas. Then do the pukka job with the benefits of CNC and make it beautiful.
    Think you got it spot on, Robin, crude conversion first = thanks I like that.
    I am a cnc -virgin, and perhaps a big concern is, will there ever be a running machine.
    My primary aim at the moment, is to get a shopping list ready.
    - For that purpose, have done now two (2) things
    1) Take measurements of the mill (King Midas)
    - take photos too.
    - Here are a couple of greasy pics, from dismantling the X/Y -table (From left to right: 1) overview; 2) X-axis dismantled; 3) X-axis leadscrew is 260mm, think it could be a bit longer; 4) x-axis one end; 5) Leadscrews are 18.34 mm thick; 6) Y-axis leadscrew at 175mm, think it could be longer)
ID:	5415 Click image for larger version.
ID:	5416 Click image for larger version.
ID:	5417 Click image for larger version.
ID:	5418 Click image for larger version.
ID:	5419 Click image for larger version.
    2) Make a sketch of the Z-axis ballscrew -conversion
    - think how the motor would be mounted
    - how long ballscrew one might want
    - how the thing would work
    - This sketch is from side of the mill. (used inkscape to create the original graphics)
    - Green is the body of the mill
    - Blue bits are those that I'd try to buy ready made
    - Red bits move up/down as "one unit", with the quill (and ballnut)
    I am a bit concerned about the (horizontal) distance between the ballscrew, and the quill.
    - the King Midas -milling machine is a bit difficult shape, like a mushroom.
    -- Thought about using pulleys/belts, to bring ballscrew horizontally closer to the quill. But then, if possible I would like to avoid any added complexity, because of my non-existing experience with these beauties.
    -- Another concern I have is the length of the Z-ballscrew (somewhere around 370mm), and no support in middle.
  1. CONVERSION: Round Column Mill Conversion - Looking for advice on Z-axis
    By cnc-joe in forum Conversion Build Logs
    Last Post: 06-10-2013, 01:22 PM
  2. RFQ: DIY amp case help with materials and HUGE pre made cost justification !
    By Fivetide in forum Projects, Jobs & Requests
    Last Post: 04-06-2013, 12:05 PM
  3. BUILD LOG: beginning steps to building my cnc
    By scnc in forum DIY Router Build Logs
    Last Post: 03-12-2012, 10:38 PM
  4. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  5. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
