05-02-2013 #11
Jazz on those piccys you posted doesn't it make more sense to put the 4th axis level slightly lower than the table instead of several inches above the table?
That way you can fit the same diameter stock in there without needing several more inches of z-axis travel.
PS this design looks like it is meant to do almost exactly what I'm designing my machine for (the 4th axis and the ability to fix pieces vertically for doing dovetails etc) Have you actually built one like this and does it work ok?
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
By Hypertherm John in forum Manufacturer NewsReplies: 0Last Post: 04-03-2011, 03:26 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM -
Need helpwiring up from scratch
By GeorgeD in forum Machine DiscussionReplies: 40Last Post: 13-07-2010, 06:23 PM
