24-10-2014 #7
Hi, thanks for the comments. jimbo_cnc I am base in North East London at the moment. As a lot of manufactures are based out of the city to keep their costs down I don't think that it will really matter where the CNC service provider is based as they will probably use a courier unless it is a huge amount of part you need cut. For pricing I have been sending all the parts off for a fairly standard base unit 600mm wide, a top and bottom, 2 sides, a back, and 2 battens for the back to fix to. The parts also have some holes for fixing through and shelf holes etc so no complex shapes or 3D work. £80 for a carcass seems reasonable, what type of carcass is that and what material? There is the advantage with Timbmet that they are a big supplier of panel products so will have what material you want to use to hand. Can I ask what they are charging you for delivery and the cost of the material? Thanks
Question on PCB and routing
By Fivetide in forum General ElectronicsReplies: 20Last Post: 12-05-2013, 06:35 PM -
routing aluminium help :)
By don_jarr in forum Metalwork DiscussionReplies: 18Last Post: 27-11-2012, 09:05 PM -
NEW MEMBER: New to cnc routing and looking to buy a machine.
By stamper in forum New Member IntroductionsReplies: 3Last Post: 03-12-2011, 03:31 PM -
BUILD LOG: routing 3d?
By proddy in forum DIY Router Build LogsReplies: 2Last Post: 03-08-2009, 11:20 PM
