Thread: Initial Design Check Please
26-10-2014 #7
Thank you JazzCNC,
That really cleared things up, expecially with the pictures.
With regards to the profile rails i had a look on ebay and they seemed to get quite $$ when i was looking at the longer lengths, but ive found them on aliexpress and they seem alot better priced and with more options, is this where you get yours from?
i had a look for the Z axis for example and found these rails
http://www.aliexpress.com/item/EGR15...828633643.html
and these blocks
http://www.aliexpress.com/item/1PC-H...044267870.html
Are these the right kind of thing? Only reason im asking is there seems to be different versions ie HGR MGN.
Sorry about all the questions.
Thanks again
Trev
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
Component Check
By manofgresley in forum General ElectronicsReplies: 1Last Post: 22-04-2014, 06:04 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
Newbie Initial Wiring/Setup
By Rikk in forum Motor Drivers & ControllersReplies: 3Last Post: 28-06-2011, 10:19 AM
