Thread: Vcarve workpiece orientation
31-10-2014 #32
I lied
phill05, if I was cutting shapes from sheet material or stock that was well oversize for the job, it would not matter that only the vectors rotate.
But if you cut like I do where the material profile is cut to size first on a saw, then clearly if only the vectors rotate they would no longer fit the stock material.
I use CamBam mostly and it's the same with that, if I apply transforms the stock material is unaffected, so what I have to do is resize the stock to orient it in the other direction, i.e. swap over the X and Y values.
Now all that is fine and I don't have a problem with that but what I am saying different to you is this, the material or stock in some instances, as above, is clearly the workpiece.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
vcarve pro 7
By GeoDurie in forum CAD & CAM SoftwareReplies: 3Last Post: 22-05-2014, 02:46 PM -
Workpiece illumination
By cropwell in forum Workshop & EquipmentReplies: 0Last Post: 29-09-2013, 10:21 PM -
Securing the workpiece
By jrob3rts in forum Machine DiscussionReplies: 3Last Post: 16-06-2012, 10:21 PM -
Vcarve to Mach3
By jcb121 in forum VectricReplies: 6Last Post: 01-04-2012, 05:21 PM -
Workpiece hold down by glue
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 30-09-2010, 08:22 PM
