10-03-2015 #481
10-03-2015 #482
I lay awake thinking about that last night and came to the conclusion that I was kidding myself it would be ok and should have known better....I'll pocket it deeper and tension the belt from the side....or weld up a bracket from steel that can slide to tension it. Cheers chaps.
10-03-2015 #483
A bracket could be made to fit in between the top and bottom plates projecting back and lapping around the back face of the two plates ( like a tee piece) it would mean the motor is sticking out the back slightly.
"TOOMAST ..Do you have special machining on ballscrew? I notice longer area for the pulley?" Just order the ball screw with the "F" measurement 30mm instead of standard 15mm. ..CliveLast edited by Clive S; 10-03-2015 at 09:28 AM.
10-03-2015 #484
Clive I'm going to pocket out the bracket that I've got and use that with a shorter belt I think....well that's the current plan anyway!
10-03-2015 #485
Quick play on the milling machine...
A few bits for my PSU came today....just need some choc block connectors and some fuses and ill be away...
10-03-2015 #486
Ok so pulled the gantry apart and machined the front and bottom plates (M8 counterbored hole in each)
Put it all back together and it's nice and solid...
Control cabinet and bits arrived just now so more stuff to play with
Going over to Wobblycogs tonight to have a catch up, talk CNC Routers and look at his control cabinet to get some inspiration...
11-03-2015 #487
OK quick question. I'm now coming to the end of the mechanical build so my mind's turning to all things electrical
When connecting the CY cable to the stepper how do you folks do it? I was thinking of either via a chocolate block as near to the stepper as possible or probably I'll go with soldering the wires with heat shrink over them and then heatshrink over the whole lot?
11-03-2015 #488
11-03-2015 #489
11-03-2015 #490
Cheers, just thought that as long as the joins soldered ok then there's no potential at the join for a loose connection.
Next question! I'm going to get a safety relay (probably a second hand Pilz from ebay) for estops, limits, home switches etc. What's a good model to get, I've seen some Pilz PNOZ X3's which seem to fit the bill?
There are currently 24 users browsing this thread. (0 members and 24 guests)
BUILD LOG: A3 Router Build
