    Thanks Jazzcnc
    I am definitely doing my homework on this, I haven't even bought the mill yet! I intend to convert the mill myself and at the very best quality I can afford. I will spend the next few months researching as much as possible and will bugging the life out of you guys on this forum. I am an electrical /mechanical engineer by trade so hopefully can pull it off! Its' just the terminology and sifting through the information that's proving difficult at the moment.
    Quote Originally Posted by Fatoftheland View Post
    Thanks Jazzcnc
    Ah well when a I said don't buy anything yet that doesn't include the Mill.!!. . . . You'll need that bugger. Lol
    Is there anybody who sell hardware to convert that mill - LongVersion?
    Looking for ballscrews, mounting plates for: ballscrew, nuts and motors.
    Ideally if handle can remain so can be used as conventional mill.
    Quote Originally Posted by Tom J View Post
    I am working on that right now. Two versions in the pipeline, servo and expensive ballscrews, steppers and cheap ballscrews. Both with handles.
    ATV the moment I am designing based on my EMV-25VBB but also have the parts that will allow use on the ama series.
    The trick is not to have to machine the casting and that is what you can expect from my kit
    https://emvioeng.com
    Quote Originally Posted by komatias View Post
    I understand that kit won't be kind of straight fit, as Y slide have to be machined to fit ballscrew nut.
    My idea of buying such a kit is to do minimum work and fairly quick change over, so kit have to be design and machined to exact mill - AMA25LV.
    I have control box with nema 34 motors and all home/limit switches.
    I decided to use cheap steppers with digital drive rather than servos as this machine is not accurate anyway so no point to spend extra money as I won't gain anything decent.
    Please give mee the quote for mechanical parts:
    brackets/plates
    both ballscrews c5 or c3 and c7
    Tom
    Tom,
    I do not know which kit you are refering to. I have a way to avoid machining the castings.
    Nema 34's will be overkill but I will provide an adaptor if you are desperate to use the kit your bought.
    As I said, I am developing it currently so pricing will come when it is all sorted.
    Send me a PM with your email address an I will keep you informed of progress.
    Tom,
    Nama 34 would be for Z, Nema 24 for X and Y have to calculate
    I was refer to space for ballscrew nut - there is not enough room for even RM16
    Could you upload picture or give the link of your kit please?
    Tom
  1. AMA25LV CNC Project !!!
    By Onocyclone in forum Milling Machines, Builds & Conversions
    Last Post: 27-09-2014, 08:21 PM
  2. AMA25lv clones
    By Onocyclone in forum Machine Discussion
    Last Post: 06-09-2014, 05:20 PM
  3. NEW MEMBER: complete beginner saying hi
    By helder1977 in forum New Member Introductions
    Last Post: 06-04-2013, 11:41 PM
  4. NEW MEMBER: complete newbie here :)
    By chudds in forum New Member Introductions
    Last Post: 18-05-2012, 08:37 PM
  5. Complete conversion kits?
    By leitzscope in forum General Discussion
    Last Post: 01-05-2010, 07:57 PM
