15-09-2015 #671
Congratulations, looking really good.
16-09-2015 #672
16-09-2015 #673
Well done Neil, it's looking brilliant from down here!
16-09-2015 #674
16-09-2015 #675
I got them from RDG Tools http://www.rdgtools.co.uk/acatalog/1...dia-14743.html when I got a load of other bits (8" Vertex indexing head etc...) I'm sure they're not the cheapest by far but I was ordering loads of other goodies.....
16-09-2015 #676
16-09-2015 #677
Ok so been playing with Cambam and doing various test cuts in a scrap piece of MDF playing with Step overs, feeds and speeds etc. Even did some peck drilling in preparation for drilling the base plate to bolt down a spoil board (MDF to start before a Tuffnol one I've got) so spoil board looks rather used...
My work area is 970mm x 495mm so not quite as large as I'd hoped...but more than enough for what I want at the moment.
17-09-2015 #678
BUGGER!!!!!!!!
Spot the snapped tap in the bed...
Close up....
Which makes the sacrificial bed look like this...
Closer...what's missing from this one???!!!!!
Any suggestions for getting the tap out in situ guys??????
17-09-2015 #679
Damn, always happens just when you don't need it. I've seen broken taps removed using a small punch or point and hammer to carefully unscrew them. Whether it will work depends how well the thread is cut I'd guess. Good luck.
The Following User Says Thank You to Wobblycogs For This Useful Post:
17-09-2015 #680
I've some bits to cut tomorrow that don't require absolute precision so ill surface the bed and then think about it.
There was a thread where someone used Alum to dissolve the tap...trouble is I'd need a big pan to simmer the bed in!!!
Ultimately it won't matter as I'll be doing the T slotted base thingy...but it's still annoying!
There are currently 30 users browsing this thread. (0 members and 30 guests)
BUILD LOG: A3 Router Build
