Thread: New build help needed
14-12-2015 #7
Vagelis is a very nice man he also makes Great wine please say hello to him for me.!!
With regards to your plans then my words of wisdom are Choose a sensible design don't go crazy regards build strength if all your mainly going to do is cut woods. Like has been said forget Steels and if you want best machine then I'll go further and say forget designing for Aluminium has well.?
Machine built to cut all materials is always a compromise, woods, plastics and softer materials mostly come under the same design class regards strength and cutting but Aluminium starts taking you away from what is optimum for this class. Which means pushing you into stronger heavier designs which start having negative affects on the machines main usage along with other negatives like.? Expense, complexity, performance with very little if any gain.
You don't need massive tube sizes and thick armoured plated tank like structures to cut woods etc. Aluminium needs it's own ideal design parameters and while it's possible to cut aluminium with a wood router it's very different to cutting aluminium correctly.
The design considerations for Aluminium which are mostly strength and cooling related both have negative affect on soft materials cutting with huge affect on your wallet to do correctly to suit both materials.
So design for wood is my advise and make it the best it can be for the intended purpose and leave the hard stuff for another build.!
Also don't need to design in Cad to the last tiny detail because things in the real world have a habbit of not fitting like they do in Cad.!! So just layout the basics to confirm lenghts etc and the design works also major components don't clash with each other. This does mean that you need to design with accurate component models or ideal models of the actual parts your going to use. Often I see people design using generic models only to find reality bite them when they don't fit in the real world like they did in the Virtual world of Cad.!! . . . . It also wastes a lot of valuable time that will be better spent building and learning than drooling at computer screen.!!
Good luck.!! . . . . . Oh and has the Lady's often find out Size really isn't everything it's how the tool is used which determines the pleasure.!. .
Build log. Design advice needed.
By eurikain in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 25-06-2015, 06:53 PM -
What's needed for a 3d printer build??
By Davek0974 in forum 3D Printing MachinesReplies: 26Last Post: 18-02-2014, 11:54 AM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
RFQ: Help needed to build my first machine NE Norfolk
By Dorg in forum Projects, Jobs & RequestsReplies: 3Last Post: 31-10-2012, 09:30 AM -
WANTED: Needed for my build
By jpcnc in forum Items WantedReplies: 9Last Post: 08-01-2011, 02:22 PM
