Page 73 of 82 FirstFirst ... 23637172737475 ... LastLast
  1. #721
    Looks good but pretty certain you wouldn't catch my fingers in the slot with the tool that close while in cycle!
  2. #722
    Quote Originally Posted by CharlieRam View Post
    Yes not a practice I'd recommend....in my defence I've run the simulation 20+ times so knew it wasn't going to rapid on me anytime soon....however I'll agree, no excuse
    Neil...
    Build log...here
  3. #723
    Good stuff Neil.
    Was that a Fusion 360 part or i-machining?
    One method I've used to avoid faffing about with zeroing off of a part like that is to cut a holding fixture in the bed and then use the same zero to then run a contour pass(es) to clean up the part.
    Of course you know Jazz is going to turn up soon and goad you into cutting deeper and faster ;)
  4. #724
    Good stuff Neil.
    Cheers Chris, it was Trochoidal machining in Estlcam. I've not really messed with fusion 360...downloaded it and installed it but I use Geomagic at work so until I get more proficient at that I'll not confuse myself by using two 3D programs....
    I'm going to give the bed another surface soon and at some point I'll put the 1" thick bakerlite sheet on and use that as my surface and tap holes into it for holding down workpieces but use sacrificial wood as necessary...
    I'll not need much egging on by Dean...I started at the speed and feed that was recommended for the cutter...onwards and upwards!
    Chris, what tape do you use to hold stuff down?
    Neil...
    Build log...here
  5. #725
    Just finished the Mk2 mount....could have been a Mk3 but this will do! Did put some engraving in the middle but got the depth wrong and it snapped the engraving bit Still I forgot the hole in the middle for the shaft to go through (manually drilled) so that would have gone through the engraving anyway....Pressed the tubes into the plate on our hydraulic press and at 2.5 tonnes pressure I don't think I need to use the Durafix to weld them in...might do it anyway but I'll see. The bolts are pulling the tubes into the plate so they're not going anywhere, just the torque twisting them. Might get a big block of Ali and mill it out of 1 block though I'll probably not bother if this works...
    Neil...
    Build log...here
  6. The Following User Says Thank You to njhussey For This Useful Post:
  7. #726
    Guessing it's for a belt arrangement for something?
    Bet your loving having a cnc up and running you can make stuff on, I can't wait :).
    .Me
    .Me
    No it's simply a spacer to hold the motor off the firewall so the propeller sticks out the nose the correct amount...
    Yeah I'm loving it, just starting to be more adventurous get it finished Lee it's great fun...
    Neil...
    Build log...here
  9. #728
    Ahh right it's for a plane!
    :) I will it's just a waiting game really, mechanically all I need for it now is two gantry side plates, two bearing plates and 3 motors, Dean is lined up ready to make the plates for me but I can't commit just yet as money is tite but I'm working on it :).
    In the mean time I've been getting a few bits together for the enclosure, I'm actually ready to go with that side of things but again with out motors to connect it all too there's no rush so to speak.
    I've just had my second injection for this new biological medicine they've put me on, I had my first one last week and the next morning I could feel the difference instantly when I tried to first stand up, normally I'm on steroids and painkillers during the day and the roids have been a great help in getting me some what mobile again but when I first wake up obviously those have all worn off through the night so I normally have to give my legs a min or two too adjust then go for it but as soon as I put weight on my feet (mainly the ball of my ankles) it's painfull, it's quite funny really because obviously as a man the first thing I need to do when I open my eyes is drain the bishop! But I can't because it's a painfull struggle getting to the bog lmao, it's been close lmao quite a few times as I've been bursting and needing to go asap lol
    But as I say the future is brite and the morning after I stood up and to my amazement there was nothing there pain wise and since I've had no pain at all I really can't believe it, the doc said it would be 3 months before I would notice it starting to work, I'm not complaining!
    Today I've been for a walk into town to get my hair cut, drop some packages off (switches for the lads) and get the girls a McDonald's for their dinner (brownie points) and I've made it back as happy as Larry because it was easy (normal).
    Sorry I'm waffling on your build log but I'm just feeling so positive at the moment and i really cant wait but i really dont care either, what's more important in life as basic as they maybe is what I'm chasing at the moment :D.
    Positive: Don't worry, my day will come and CNC better be ready for me 😎
  10. The Following User Says Thank You to Lee Roberts For This Useful Post:
  11. #729
    Hi Neil,
    Sorry - missed the question at the bottom - I use this tape:
    Silverline 198134 Fixman Double-Sided Tape, 50 mm x 33 m from Amazon
    http://www.amazon.co.uk/dp/B00F80K5OS
    Chris
  12. The Following User Says Thank You to Washout For This Useful Post:
  13. #730
    Glad you're on the mend and things are getting easier for you to do normal everyday stuff...that's great news!
    Hopefully things pick up a bit now and you can crack on with the build, look forward to seeing it!
    Neil...
    Build log...here
  14. The Following User Says Thank You to njhussey For This Useful Post:
There are currently 30 users browsing this thread. (0 members and 30 guests)
  4. BUILD LOG: A3 Router Build
