    The cost of servos is going to be quite high, so i'll probably for closed loop steppers instead. However the ClearPath servos seems tempting. Is there any good reason to use servos instead of closed loop steppers?
    Quote Originally Posted by PotatoMill View Post
    Closed loop steppers don't have the speed or torque capabilities of servos and are sold as an 'economical' alternative. The only good reason to use closed loop steppers is because they are cheaper.
    Some cheap servos like the JMC can be similar price to most closed loop steppers, it'll be interesting to know if anyone has tested how their performances compare.
    Cheers,
    Fenza
    Thanks for the quick response Fenza and Remrendes
    According to a quick estimate I did I dont think i'm going to need any more torque than what these closed loop steppers deliver; http://www.aliexpress.com/item/new-o...a-82b3fb4b4813
    Estimates done with
    -40kg weight of moving part
    -130N force of cutter (excessive)
    -20N friction
    -85% efficiency
    -10 m/s^2 acceleration (more than I think i'll need, but I haven built any CNC machines before so i'm not certain on this.)
    -5mm lead
    Using T = (F*l)/(2*PI*n) where F is total force, l is lead per revolution, n efficiency
    I get 0.44N well within
    However I do know that theory and experience dont always match up. And in real life there could be some factor that make the estimate wrong.
    Estimates done with
    -20N friction
    -85% efficiency
    -5mm lead
    Hi PotatoMill your math certainly is correct but it doesn't account for the full picture. I use Kollmorgen MOTIONEERING to calculate more precisely what kind of motors are required, it's a little tricky to understand in the beginning but sticking with it pays off massively! http://www.kollmorgen.com/en-us/serv...eering-online/ here's the link to their site. I use their older application at the bottom of that page, it looks like they have a new online tool available now.
    Kollmorgen have a huge range of motors available and the MOTIONEERING app helps point you to which is suited for your machine, I just use the data from that motor to base my search for a cheap servo / stepper system off of.
    Also always remember that steppers holding torque is not the same as a servo rated/max torque.
    A good rule of thumb that I use (though I'm not entirely sure it's correct) is that a 3Nm stepper is roughly equal in power to a 100W Servo.
    Hope this helps!
    Fenza
  5. The Following User Says Thank You to Fenza For This Useful Post:
  6. #5
    Quote Originally Posted by Fenza View Post
    Hope this helps!
    Fenza
    Great tool, very helpful. I'm trying both the new and old now, the old one seems better actually.
  7. #6
    Estimates done with
    -20N friction
    -85% efficiency
    -5mm lead
    With 5mm lead is not the best ballscrew for you. You shoud use the motors up to 500rpm. Under this, you nearly can get a full holding torque.
  8. #7
    Both have a feedback to driver, so both are better than a normal steppers.
    A cost of the servos is higher than what you think. E.g. you have to reduce the rpm, with 1:2 - 1:3 transmission. 1x zero backlash pulley is approx £30-40, one belt can be £15-20 and you need 3 set. With steppers, you just need a coupling.
    Unfortunately I started with servos, but I could get a cheap set from China.
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. BUILD LOG: Aluminium Framed Router
    By lucan07 in forum DIY Router Build Logs
    Last Post: 04-05-2016, 09:06 PM
  3. 600 x 400 Aluminium Profile Gantry Router
    By Journeyman in forum Gantry/Router Machines & Building
    Last Post: 02-03-2016, 04:28 PM
  4. RFQ: RFQ: Aluminium parts for my CNC router
    By biketrialsdave in forum Projects, Jobs & Requests
    Last Post: 12-10-2014, 10:06 PM
  5. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
