Thread: Warco WM16 CNC Conversion.
13-01-2017 #8
Just read your post again Jo and see your dilemma, clamp 2 bits of 3"x2" wood together and drill a 14mm hole or largest drill bit you have nearest that size if not got that size, equi spaced through the join. Do this twice and use them as clamps for your ballscrew. Then screw them down to a flat work bench/door (but maybe not kitchen worktop.....unless you're single 😉) with a suitable spacer underneath them so you can turn your die without hitting the surface. Screw down a batton parallel to your ballscrew 25mm offset from it and then make yourself a 345 triangle that you can use to slide against the batton thus keeping the die square to the ballscrew....
Sent from my HUAWEI VNS-L31 using TapatalkLast edited by njhussey; 13-01-2017 at 06:21 PM.
The Following User Says Thank You to njhussey For This Useful Post:
There are currently 13 users browsing this thread. (0 members and 13 guests)
Warco WM16 Mill - Conversion to AC motor with VFD
By birchy in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 10-02-2022, 07:41 PM -
Warco WM16 Conversion
By birchy in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2011, 09:32 PM -
Warco mini mill cnc conversion
By buster in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 20-03-2011, 07:48 PM -
CONVERSION: Warco VMC Turret Mill - CNC Conversion
By antsals in forum Conversion Build LogsReplies: 33Last Post: 07-03-2011, 12:25 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM
