02-03-2017 #36
I don't think it's unacceptable to be creative, innovative or experimental. However your not being creative or innovative.? You are being Tightfisted and cheap which are not to be confussed with the latter.! . . . . . If you took the same approach in baking Cake the outcome would be the same.? . . . It would taste Shite and end up in Bin.!
Experimenting is fine and something I fully encourage. But your not inventing or creating anything that hasn't been tried before by others dabbling in CNC. So please don't try to tell others that what your doing is OK and will work fine for CNC machine.! . . . It's not, it's complete rubbish and by the very nature of innapropriate components used along with piss poor engineering is doomed to fail.
So when experienced builders comment don't take it as being negative because they are actually trying to advise YOU and OTHERS against making big mistake.! . . . The time you have wasted on this crap would have been better spent reading the forum and then searching Ebay or selling sites for deals on suitable components. Just like if can't bake Cake better going to ASDA.!Last edited by JAZZCNC; 02-03-2017 at 09:11 PM.
BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
By Tom J in forum DIY Router Build LogsReplies: 14Last Post: 02-01-2017, 09:32 PM -
Small Fixed Gantry Router Spec and Build
By shaunrod in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-07-2016, 06:55 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM
