Thread: Temperamental spindle
23-08-2017 #1
a few years ago JazzCNC built me a router, however this last year I've had a reoccurring issue- the spindle either stops after a few mins, or more typically just doesn't start, the VFD has no reaction to mach3, even hammering the spindle button on mach3 has rarely worked.
Normally it's just a minor niggle - I leave it for switched off an hour and it magically works again (any less than an hour and it doesn't!?) but today it did 4 mins work and then decided no more, and the VFD hasn't reacted to mach3 since.
I've tried2 PC's, and changed the Ethernet cable, but neither has made a difference.
I'm not too technically minded, but maybe someone can help (Dean??)- I have taken a pic of the VFD, I've no idea why!
All I can tell you is the taped off wire is because the water pump was playing up a while ago and so I disconnected it- it's not made much difference as I haven't run any long toolpaths since, and it's sadly not corrected the issue!
Cheers for any thoughts, it's been a stressful day!
MarkLast edited by mark84; 23-08-2017 at 04:35 PM.
23-08-2017 #2
OK Mark Have you tried shorting the FOR (green/yellow wire) and the DCM (black wire) terminals together.
Remove them from the terminal block and link the two terminals. the motor then should run. That will prove if the relay on the bob is faulty..Clive
23-08-2017 #3
Clive, thanks so much for the detailed reply. I tried what you said, the vfd tried to accelerate up presumably too fast and makes the distinct click of a circuit breaker or similar, presumably because it misses the speed, however, as I power it down and a second click is heard as the vfd releases the spindle very briefly spins. I'm not sure where to go from here.
Thanks again for the reply Clive, it's much appreciated
23-08-2017 #4
So if I understand what you are saying. With the FOR and DCM (without the original wires connected) the spindle powered up, If then you remove the link the spindle should stop. If that is the case then check the original cables from the FOR and DCM back to the BOB and makes sure the connections are secure. A picture of the bob might help
24-08-2017 #5
24-08-2017 #6
Ok I think that the two cables that go to the vfd that control the spindle stop/start are the one's that I have put a red ring around.
Make a note of which terminals they are connected to. Then disconnect them and check them for continuity to the vfd FOR/DCM if necessary remake the connections.
I have never used that controller but I can see Dean's influence in there .
24-08-2017 #7
26-08-2017 #8
I couldn't find any issues with the wiring, though I've taken the connections out and cleaned them before tightening up again, and it's working, I'm unsure if that's just coincidental but at least it's ok for now.
If the problem keeps happening could I move the connection to the next port across?
Thanks for your help Clive :)
26-08-2017 #9..Clive
26-08-2017 #10
Clive
I've just read post #3 and to me it does not sound like joining FOR and DCM is running the spindle all the time. Have a read and see if you agree.
Mark,
When you connected FOR and DCM the spindle briefly accelerated then cut out. It remained stationary until you disconnected FOR and DCM at which point nothing happened until the electronics had 'spooled down' to a low rpm at which point the spindle burst into life and tracked the speed down to zero. As if there is a dead spot above a very low rpm at which the spindle will not turn. Is this what you observed?
If I got this wrong please carry on. If not suggests VFD is faulty or has wrong settings?
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
