Dear Boyan,
Not sure iam really clear what your preference is.
Do you mean use a single motor on 2 belts solution?
Mechanical advantage is :
- Y axis can not get out of alignment easy?
* disadvantage idler pullys
or
use 2 motors and solve alignment in the homing sequence by electronic controls...
- Y axis can be aligned easily that way.
* Some (cheaper) controls dont do gantry squaring sequence.
09-09-2017 #2
if you are experienced with belts, know how to tighten properly long belt, know how to align all components then go with 1 motor and belt system. If you dont have the space, have a suitable controller board, go with motor each side. At the end is a question of convenience.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
