17-10-2017 #31
Next question.
M5 bolts for rail and carriages .
Will a typical hex 8.8 / 12.9 m5 x20 do?
What did you guys buy?
Grtz Bert.
17-10-2017 #33
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
17-10-2017 #34
Hi Clive,
Yes, i discussed this with Fred.
He is a patient guy
I want some spare cm of travel in the Z design... i am not sure i like the height of the z axis though.. I like compact.
I want the extra head room in z ballscrew for MK1a gantry...
what ?!!! NO NO NOO... 🤤🤤🤤
No.. im not sure 80x 120 will do and calculate in a design change to a more beefy gantry ....some day... with more travel...
Well i want at least 200mm +Z travel.. so
Travel + nut + bf bk + F = 30 for pully =
+/- 320 .. so 350 for Z should do.
Grtz Bert
17-10-2017 #35
Yes those.. exactly.
But... 8.8 or 12.9
Like your good ol bolts or tougher machine bolt style.
Does one need high tensile strenght?
I will be tapping in the 4mm steel from box section for the rail. all 200 or so off them.
Carriage bolts will have some extra meat to grip on to (4+5 mm) it has less bolts so ... well more doesnt hurt there.
Grtz Bert.
PS
Where does one buy kinda good machine taps for this purpose, not sure what makes an economical machine tap.
Just standard cap heads black or zinc etc.Like your good ol bolts or tougher machine bolt style.
Cutwell do good taps...Clive
18-10-2017 #37
8.8 means tensile strength of ~800 MPa and yield strength of ~80% of this
12.9 means tensile strength of ~12 MPa and yield strength of ~90% of this
So 12.9 will be much stronger than 8.8 but you are usually not interested in that. You are unlikely to create forces high enough to break the bolts on a diy machine. 8.8 MPa is quite a lot !
What you are interested in is the stiffness of the bolts as this tells you how much deflection you will get when machining parts. But this will be similar in both bolt types so 8.8 will be fine. No harm in using 12.9 but they won't give you any benefit.
If you are interested in why it is because the stress/strain curves have the same slope, it is just that the 12.9 bolts will go further along the curve as they are stronger.
If you buy stainless there is a different naming system as stainless does not really yield before it breaks (by comparison) but again there is no diy CNC advantage other than looks nice and won't rust
The Following 2 Users Say Thank You to routercnc For This Useful Post:
18-10-2017 #38
18-10-2017 #39
Looks good!
28-10-2017 #40
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
