    Nice!
    Must feel great :D
    Relieved ;) I tested it without the capacitors but since I put it together properly I hadn't tested it will try to remember to test the output voltage tomorrow.
    I have no resistor on the output of the PSU so the capacitors remain charged at moment what's the best way to discharge them or should I just shield them so you can't touch the easily instead?
    I'm going to wire a 32amp socket to the wall and then from that to the junction box, from there to the PSU, VFD and to a double wall socket.
    The PSU and spindle will be fed through a 13amp switch first so I can turn them on/off with a single flip.
    For now though it's wired to a 13 amp plug, I don't think it's wise though to run the machine, PC and vacuum cleaner on a 13 amp socket.
