Page 42 of 63 FirstFirst ... 32404142434452 ... LastLast
  1. #411
    Got the spindle back on was nice to see it move with the spindle on and test the water cooling hoses for kinks, etc during movement.
    I am going to put the limit switches sideways on like someone suggested maybe 3cm away from the original switches, ordered a couple of roller type ones and have 1 spare. The original ones going to leave in place as hard limits so when I do get a latched relay I can wire it to that with all my other emergency stuff.
  2. #412
    Water cooling works ;)
    Still waiting on roller limit switches, box is 90% finished now.
  3. #413
    Still no roller switches but found a spare one so i can fit 2 for the Y axis over the weekend, getting it fitted in place finally.
Name:	Box electronics.jpg
  4. #414
    Awesome! :D
    What type of rollerswitches did you get?
  5. #415
    Awesome! :D
    https://www.ebay.co.uk/itm/1PC-Micro...72.m2749.l2649
    I got 2 of these and have 2 honeywells same type already.
    Now I've found the missing one I can sort the Y out which is the most important anyway as I'm going to use the switches to square the gantry when homing. This is going to take me a little while to work out in linuxcnc lol.
  6. #416
    Was thinking about that type aswell.. have some somewhere :D but Im probably gonna buy this kind https://m.ebay.co.uk/itm/Blue-ME-810...IAAOSwIgNXjh-v
  7. #417
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I personally would go with this type https://www.ebay.co.uk/i/22256467184...4960578&crdt=0
    No moving parts to go wrong.
  8. #418
    To tell the truth Ive bought that kind for my home switches, was thinking about going mechanical for my limits because of all the forum threads I have seen about connecting proximity switches and different types (npn, pnp) and the problems people have in connecting them. I guess its not complicated and if I get confused I could always get my multimeter and figure out whats going on.
    But I just dont want anything more complications right now :)
  9. #419
    Yes you are correct they don't need to be accurate for limits and easier to connect in one loop.
  10. #420
    Am I right in thinking it's pointless to use limit switches if you're only going to wire them to the Estop as the home switches can do the same job? They become useful when fitted to an external override like a latched relay?
    Is this correct?
