Thread: AXBB charge pump fault
So the LED on the AXBB is off, but the relay remains energised and another LED on the relay is on/dim?
That suggests the FET is conducting, when it should be off. No disrespect to John but worth a visual around the replacement FET and a wipe down with IPA if there's any flux residue, but I doubt that will resolve anything (the gate is tied to ground via resistor so can't really believe any parasitics will be able to draw the gate high). Worth measuring the voltage on the gate of the FET (report here) and the voltage ACROSS the relay coil when it should be off - my guess is you'll have a few volts there and if the voltage on the gate is essentially zero then, with the circuit as shown, it can only be the FET. Replace again. If it fails again then replace with a bigger bugger. Or haywire the 74HC14 output to the adjacent FET and use that output instead.
16-11-2019 #2
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Not sure where the fault lays
By terry1956 in forum VectricReplies: 5Last Post: 20-02-2019, 11:28 AM -
fault testing
By Palletlad in forum General ComputingReplies: 2Last Post: 09-02-2018, 05:51 PM -
Jun-Air Compressor Fault
By jamesgates1000 in forum General DiscussionReplies: 5Last Post: 02-12-2017, 07:59 PM
