Thread: NordicCNC's build log
07-03-2020 #2
Great and you have explained it very well!
By the way I have now decided that I will not use the 180W JMC servo motors that I bought in advance. I've come to realize that they are holding me back by limiting the weight of he machine. It was an expensive learning lesson but now I know that I should always wait with buying any components until the design is completed.
I've contacted the supplier and they might be willing to accept a return and I would pay a little more to get the 400W JMC servo motors in change (https://www.aliexpress.com/item/4000067490526.html). In case they don't accept the return for some reason then I have already found another use case for them, so that problem is solved - no money lost. If I then still buy the 400W JMC's, I don't know, I will have to check what you and the others here think. I saw that delta servo's were recommended as well and it was also mentioned that larger than 400W would probably be good?
Anyway the motor power issue is now out of the way and I have the money to spend on new and way more powerful motors!
So now having solved the motor power issue, do I still keep the Z-axis weight as low as possible or should I start trying to beef it up? The covers I will design to be structural, taking ideas from your machines JAZZ. The Z-axis front plate I am not so sure if I can improve much since it is already very stiff. Perhaps the Z-axis design is good as light weight and I can just stop worrying if the motor power will be enough to handle the heavy ATC spindle!
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
