Thread: NordicCNC's build log
I totally missed that.. It is of course the X-axis in your case that could perhaps need a brake, but seems like its fine without.
Would there be any chance that a 400W Delta servo with brake couldn't handle my Z-axis of around 25-30kg, with a 2:1 reduction or even 1:1? I could go for 600W if that would be better.
Got it, thanks again. I will now completely forget about these servos with integrated drives.
Skickat från min SM-A530F via Tapatalk
12-03-2020 #2
The Following User Says Thank You to jarjar For This Useful Post:
12-03-2020 #3
12-03-2020 #4
Nordic: Forgot to say in the previous post when mentioned about higher-level servos requiring higher quality components. That this is also true to lower degree for cheaper servos over a Stepper system.
For instance, with motor coupling used on Stepper, you can get away with more springy coupler and it won't affect the motor in any way. Whereas a springy coupler on even a cheap servo system can cause big issues with tuning the motor. The same goes if using belts and pulleys, buy good quality belts and pulleys.
The stiffer you can make the coupling between motor and screws the better this goes right down to motor mounting. Flimsy motor mounts etc will cause resonance which you'll have to tune out of the system. This isn't always so easy with cheap servo's so the more you can do to limit resonance the better.
12-03-2020 #5
I have never used servos before so I am not familiar with how the tuning works. All I know is that the Delta servos and most of the other servos comes with some auto tuning software. How good auto tuning works I have no idea.
Seems like tuning manually is very difficult and requires a lot of experience to get it right. If you don't know how to do it, the servo system would end up being even worse than a stepper system. I am starting to wonder if I would be better of with a good stepper system instead of diving into the realm of servos.
To me it seems like you favor steppers at for your own builds, but I may have got this wrong. If I am right, I guess you favor steppers for the simplicity and the above reasons?
By the way what would be a good supplier for belts and pulleys? What supplier are you using?
Thanks again for your great insight!
Skickat från min SM-A530F via TapatalkLast edited by NordicCnc; 12-03-2020 at 08:35 PM.
13-03-2020 #6
Yes exactly for that reason! The machines I build mostly go to MEN in SHEDS type users or small business where the speed or high resolutions etc servos offer isn't needed. Reliability and simplicity are more desirable than speed for these users. Also from my point of view it also means less work and happy customers.
A good properly sized and tuned closed loop system is more than good enough for most builds and far simpler.
I use a local supplier.
13-03-2020 #7
Glad to hear this actually. Of course it is nice with speed and the non-existent noise! Who would not want 20m/min if they could have it. Anyway 10-15m/min will probably be enough for most small businesses and hobbyist (like me) as you said. I will let this thought about steppers sink for a while before I make any decision. The design is still not finalized anyway so no need to rush things.
You said you are using Lichuan 8Nm 230Vac for the build with the ATC spindle and that you use Lichuan closed loop system nowadays for your build. I checked aliexpress and they are all either 2 phase or 3 phase. So they work with a 3 phase output but uses only 230V? I did not find any 8Nm steppers, but I found this one: https://www.aliexpress.com/item/3279...52606833P16XMw
Okay, I will research area more. I read somewhere that GT2 is supposed to be really good quality compared to the commonly used HTD 5.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
