Obvious when you point it out!
I like the grub screws and epoxy putty idea, but might it be better to use ordinary bolts instead? It would mean a slightly thicker layer of putty but it would allow you to adjust each bolt with an open spanner while the gauge is on it's head rather than have to measure, move the gantry away to adjust, move it back to measure, move it away to adjust again etc.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
24-06-2020 #2
No point really and you want to be measuring off the bed not the bolt head. A M3 or M4 socket cap grub screw is easily adjusted thru the hole and is small enough not affect the bed too much.
There are several ways to do the same thing and it depends on how your planning on using the bed regards fixtures etc. The main point was Epoxy putty works good for this application, it could easily be car body filler(Bondo to you upside downers) if your on a budget...Lol-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
