Thread: Cncst4060
04-09-2020 #10
Entirely possible. My thoughts are varied but includes insulation breakdown or stray wire from phase pin on the connector to the spindle housing.
I'd pull it apart, but I wouldn't recommend others to try.
The next test was to be a continuity test between the phase outputs on the VFD, then upstream to the spindle harness then the pins on the spindle, as well as a visual check on the terminal wiring but, again, I wouldn't recommend this if a replacement is an option.
The Following User Says Thank You to Doddy For This Useful Post:
