26-01-2021 #2
That's a bit rubbish if you can't use a step/dir output to control a spindle.
Other options to look at that would be a direct plugin to a parallel port, would be the CNCDrive UC100, or the PMDX-411 (which is Mach 4 only).
If you're wanting to rewire and do away with the parallel port, there are a lot of other options.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Looking for parallel port cable
By eurikain in forum Computer HardwareReplies: 3Last Post: 20-02-2016, 01:51 AM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
