I'd go UC400ETH. Runs Mach3, Mach4 or UCCNC if you fancied a change.
Or buy a used dell with pport, load XP on it, and away you go. That's what I did for my mill. (but I already had retail discs XP from 2005 so not an issue for me).
25-04-2021 #2
I finally went for an ESS installation and that has worked well and it installed with pretty well no problems. I had already gone through the second hand Dell route a few years ago and it was this computer that had given up the ghost. I thought that the supply of old parallel port PCs would probably dry up and thought it was about time I moved on to something that would work with up-to-date PCs.
Jim.
25-04-2021 #3
Looking for parallel port cable
By eurikain in forum Computer HardwareReplies: 3Last Post: 20-02-2016, 01:51 AM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
