Page 11 of 15 FirstFirst ... 910111213 ... LastLast
  1. Ither a FK or FKA depending on what model mount hes go!
  2. #102
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I read it as the shaft has moved through the bearing block, which in turn has pulled the lovejoy into contact with the housing...
  3. #103
    Ye but what shaft.? Motor shaft.? or Screw shaft.? Either way neither should be floating.? . . .something seems strange.!
  4. #104
    This pic from earlier in the thread reveals all.
    Attachment 4012
    The motor coupling would have enough movement in it to allow the pulley shaft to hit the mount without losing drive.
  5. #105
    The shaft that connects the motor to the x axis pulley is the one which has managed to move through the bearings so that the coupling was rubbing against the motor mount.
    A picture of the complete motor mount. I didnt think that the shaft would travel through the bearings so I didnt fit any locking collars. I will make them and fit them on the motor side of the last BK mount before the pulley. This will stop any further movement.
    I suspect this has been caused by the pull on the shaft from the tension on the pulley belt but this is a guess. Seeing as I had to hammer the shaft through the bearings I really didnt think it would move.
    Ian
  6. #106
    m_c,
    thanks, I really need to learn to type with more than two fingers.
    Ian
  7. #107
    I feel sorry for those bearings. Hopefully you just hammered on the inner ring. Often heating up the bearing first does the trick if it's that close.
    Then learn with this, you won't regret it. I have been using this layout for about 5 years now:
    http://www.dvzine.org/
  8. #108
    Jonathan,
    I dont like heating up bearings. I just normally put the shaft in the freezer for a while and yes I used a tube the same diameter as the bearing inner to hammer the shaft in. With a nylon hammer I might add.
    Ian
  9. #109
    Ian
    Argh I see now but I would call this the Y axis and the earlier post said X axis thats what's thrown me.!!
  10. #110
    Jonathan,
    Ian
    You don't have to heat bearings up that much. 100degC is more than enough for installation, and it won't do any damage to the bearing or whatever grease is inside it.
    Often sitting them on top of a hot radiator for an hour or so is enough to give that bit vital clearance for easy installation.
  1. BUILD LOG: It's begun....
    By Washout in forum DIY Router Build Logs
    Last Post: 07-06-2015, 10:03 AM
