Thread: Ready Steady Eddy
Well I'll be having the wood burner going anyway, it says the pot life is about 40 minutes so surely that's enough for it to settle ?
For making the trough I was thinking about using this, do you think the epoxy will eat into it ?
10x10mm, 1.75M, Foam Sealing Tape Adhesive Strip, Draught Excluder, EPDM Rubber | eBay
Edit: this is better, I'd missed the fact that previous stuff was only 1.75m long.
http://www.toolstation.com/shop/Iron.../sd2802/p70101Last edited by EddyCurrent; 28-01-2014 at 11:01 PM.
28-01-2014 #2
28-01-2014 #3
28-01-2014 #4
28-01-2014 #5
I take it that you have seen the pics that I posted. When the mdf sides were taken away you will find that the epoxy has crept up the sides a little. I then used a flat file to scrape the high sides away just until you see it marking the centre. I left mine to cure for about 3 days before removing the mdf. I just drilled through the epoxy and steel and then threaded in the normal way. It was way easier than I had thought.
When mixing the epoxy I did it by weight, I was told by the very helpful people at Wests to mix it in a wide container as that would produce the least heat. There is no problem with mixing it in one or two batches, I also used a hot air gun to flash the surface after it was poured to get rid of any bubbles in the surface. I believe that the proportions of the two part mix should be done accurately . Hope all this helps biggest tip is sealing the moat for leaks before you start as that will give you problems. ..Clive
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
