Page 4 of 29 FirstFirst ... 2345614 ... LastLast
  1. #31
    i had intended to use 20 mm rails on the z axis but after reading the various posts of your good self I am now going to use 15mm rails and guides to suit so i think a redesign is in order.
    the rear plate should be shorter alright i just left it long enough to house the motor with a body of 100mm long and a plate to hold it.
    i suppose the travel of the z axis could be longer but i went with that travel because of all the discussions about the length of the lever created by the extension. i suppose it's another trade off , keeping it to a minimum while having enough scope to machine to a reasonable depth. i'll get cracking at it again tomorrow, my shutters are starting to descend !
  2. #32
    Quote Originally Posted by PAULRO View Post
    No I wouldn't. There's very little price difference between 15 & 20 and the bearing size and overall height makes building the z axis easier regards clearence for ballscrew. With 20mm you still need to machine a recess for the ball screw but it doesn't need to be so deep. With 15mm the recess is too deep so you end up having spacer blocks and this makes achieving accurecy that much harder.
    In the past I've made Z axis for people who use 25mm rails just to get around having recess or spacer blocks thou I wouldn't take that route personally.
    I've got 180mm on my Z axis and I rarely use more than 100mm and often it's much less than 80mm and most of this is for tool clearence not actual cutting depth so don't go chasing length as you'll probably never use it.
    The fact you will have adjustable bed means you'll find a balance between Z extension and strength for the type of work your doing. This is the beauty of the movable bed you are very flexible and can always find the best height to suit the job IF NEEDED.!!! . . . I highlight these words becasue in practice you'll rarely move the bed (Because it's a pain in the arse resurfacing) but instead find that balance I've spoken off.
    In normal DIY wood working every day use your very unlikely to use tools with over 100mm cutting length so I find 100mm is more than enough on a adjustable bed machine as I can always bring the work to the cutter if needed or create clearence by lowering bed.
  3. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  4. #33
    i had used 20 mm flanged bearing blocks in the original dwg and that impacted on the clearance for the ball screwnut. I had also designed the z axis plate to be machined at 160 mm wide to try and keep the gantry length to the minimum . I should have used 20 mm square type bearing block to give more clearance and accommodate the 160mm width. ya i will stick with the z axis travel of 150mm - 160mm and adjustable bed. good call. i will have to get a supplier organized for the guides and rails. I dealt with chinese suppliers in a previous job and there were reliable so i'll drop them a line and see where it takes me. maybe i should wait until i have secured the rails and guides before I go any further with the z axis design?
  5. #34
    Has anybody used the linear guides and rails from Chai? i have organised the ball screws from him and thought i would use his linear gear but only on a recommendation from the previous builders here.
  6. #35
    [QUOTE=EddyCurrent;60688
    Have you thought about how the 4th axis will physically attach to the frame ? and will material held in the chuck be parallel to the X plane or the Y plane ?
    I'm thinking about a 4th axis myself but there's no room in my control panel for the gear, but thinking about it I feel it would be best as a stand alone unit with control wiring back to the main panel via plug & socket.[/QUOTE]
    apologies for the delay in getting back to you Eddy, i haven't decided whether to mount a plate to the inside frame to house the chuck or sit it on the blue frame dedicated for the fourth axis. I plan on clocking it true it with a clock attached to the gantry, with regard to the separate panel i hadn't really thought of that option but now that you say it ..... i haven't sourced a panel yet . i'm hoping to pick something up in the region of 800 x 600 x 200 deep if its not too expensive. i have off cuts of 1mm galvanized sheets getting in my way and if the parts that i ordered from Chai are on a slow boat then i might toy with that idea for a panel.
    by the way can you recommend any supplier for linear rails ?
Name:	CNC ASSEMBLY.jpg
  7. #36
    Don't be apologising to me, it's your thread.
    Well sometimes I can't be bothered to piss about looking for the cheapest, so I go for the easiest. In my case I bought my rails and bearings from cnc4you.co.uk
  8. The Following User Says Thank You to EddyCurrent For This Useful Post:
  9. #37
    If your talking about the Profiled linear guides then yes I use them all the time and they are fine.
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  11. #38
    steel has arrived and is cut and both sidewalls are welded.
ID:	13138Click image for larger version.
    I have to string the crossbeams and tie both together.
    I contacted http://www.ecfibreglasssupplies.co.uk /to purchase epoxy 105 and hardener 209 but drew a blank . apparently they don't stock 209 hardener but told me the 205 or 206 hardener are very similar but for pot time and cure time. has anybody used these hardeners? i'll probably go with the 206 because it has a longer pot life but would like some feed back before i do.
    i also spoke to Chai about his linear guides and rails and the preloads are as follows
    Z1: 0-0.02C or Z2: 0.02C-0.05C . i'm sure either of these will do the job but would like to know which preload is the preferred choice for wood routers.
  12. #39
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Paul I contacted ecf as that is where I purchased mine from they don't stock it but they can order it, but they will not deliver it out of the country. Here is a chart that will show you the difference between 206 and 209 (page 3) http://www.paynesmarine.com/document...0Adhesives.pdf as far as I can see the 206 cure time is about 9 to 12 hours and the 209 has a cure time of 12-24 hours but the 209 is recommended in hotter conditions. The idea behind the slow cure time is not how long it takes to pour it, as that is only a few minuets but the time it takes to let it level out. ..Clive
    I have done a bit of research and you can buy it in Dublin here:- Waller & Wickham
    Unit 96, Baldoyle Industrial Estate, Dublin, , Republic of Ireland
    353 18392330 He will be in his office around lunch time today.
  13. The Following User Says Thank You to Clive S For This Useful Post:
  14. #40
    Clive Cmon he's in Ireland don't think finding a cool days is going to be a problem, . . dry day well !! . .
    Paul I've used epoxy with equivalent cure times to 206 in past and had no problems but like clive says the conditions must be correct. Infact I've just ordered some 206 because ECF didn't have the 209 and couldn't wait or fancy being ripped off.( wanted nearly double the 206.!!) and I don't envisage any problems.
  15. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
