  1. #17
    Jon.'s Avatar
    Location unknown. Jon. Last Activity: Has a total post count of n/a. Referred 6773 members to the community.
    Really id say its down to personal preference. I think if your using an Ethernet controller over usb because of noise its because you haven't taken the correct steps to shield the controller and that you are also happy to have your controller bombarded with noise, just because it can it doesn't mean it should. You may be correct in that ethernet has better protection against noise but that is providing the noise is entering via its ports. If your talking about noise that is infact capable of entering a grounded enclosure then there's no telling how that noise is going to enter the board, but you say it does fair better but with the correct steps either can work so again personal preference.
    Bearing in mind a pc usually has multiple usb ports, but can only handle a single ethernet port so its restrained in that respect.
  2. The Following User Says Thank You to Jon. For This Useful Post:
  1. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  2. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  3. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
  4. Pros and cons of climb milling in wood
    By Richie in forum Wood Finishing Tips & Tricks
    Last Post: 14-06-2012, 05:09 PM
  5. Types of Ballnut and preload, questions - pros & cons ?
    By Jon S in forum Lead Screws, Nuts & Supports
    Last Post: 16-01-2012, 03:39 PM
