Just swap the relay wiring. Instead of having the relay having a permanent 24V with switched 0V, swap it so it's got a permanent 0V with the 24V coming via the CS.
That's the way analogue drives work. When the controller is active and running closed loop, it's continually adjusting the supplied voltage to hold the servo stationary, remove the closed loop or disconnect the control wire, and most servos will move, due to the internal circuit design and/or even interference/noise generate in the wiring. That's why the drive should be disabled when the controller isn't active. Most modern servo drives do let you program in a 'deadband' zone, which allows you to create a voltage range where the drive will not move, but it's not something that's needed when a CNC controller is involved. It's a feature more aimed at where servos are being manually controlled via something like a speed pot, where you need a stationery position from a basic voltage control.also dont understand why, when Mach3 goes into 'reset mode' that the machine moves itself in X and Y positive direction. I think disabling the drives will help here, currently the DER relay is kept powered (well, zeroed, 24V is permanent) via hardwiring.
One thing to note with the Kinco drives (certainly the CD4x2 ones I used), is you can invert the input/output logic via the software. IIRC by default, things like fault outputs are only activated on a fault (bad choice from a failsafe point of view, as it means any fault in the fault circuit could cause the fault signal to go unnoticed), but can be swapped by clicking the suitable button on the input/output config screen (that's not the correct name, but I've not got the software installed to check just now!)Ill swap the logic and then use one of the enable outputs, like what I am doing with the new Kinco drive that replaced a damaged IRT drive.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
19-07-2015 #2
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
