24-11-2015 #28
Summarize, if I use TB6550 or similar BOB which has only 5 inputs: 1-X, 2-Y,3-Z,4-Limit/E-stop,5-GND than 3 switches used as home/limits detect the ground signal (NC-active low). Mach knows that this axis is in home position.
How should I wire if I use the same switch as Limit? Can not wire the same switch to pin 4 (limit/E-stop)
Using pin 4 will collide with homing (all switches will be in parallel - remaining two will have NC contact therefore no homing)
Jazz, could you please send the wiring - loosing plot.
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
