    you remove the pulley to reveal the tab nut and tab washer.
    fold down the tab washer leg which stops the tab nut from rotating, then you can tighten tab washer.
    only way ive found to do it, is to tighten put back together and check back lash, if still there remove everything and tighten even more. back lash should be checked using a test dial indicator
    you remove the pulley by undoing the grub screw located in between the teeth
    Chaz's Avatar
    Quote Originally Posted by andy_con View Post
    Ye, that's what my poor PM was trying to explain.
    Anywhere where there are angular contract bearings requiredpreloaded and there are two in the end green part of the table
    Thanks guys.
    This is great. I understand it now. Basically, I am adjusting the ballscrew tighter by the tab nut and tab washer!
    i2i's Avatar
    Not really, you're adjusting the preload on the pair of angular contact bearings in the green block that fixes the ball screw to the table.
    Quote Originally Posted by i2i View Post
    ...the blue ones in the illustration below. I was trying to figure that out.
    i2i's Avatar
    the drawing doesn't really represent the action, but that's where it is.
    Quote Originally Posted by stallone View Post
    This drawing is not correct as it is not showing the inner part of the AC bearing
  1. CONVERSION: Denford Triac VMC with ATC Conversion / Fix
    By Chaz in forum Conversion Build Logs
    Last Post: 07-08-2017, 03:41 PM
  2. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  3. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  4. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  5. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
