Thread: Thor, or should that be Zeus?
I need to check, I bought two sets of components from my supplier, I think all in for 4 x 1180mm 45 Bosch rails plus carts plus around 6 different ballscrews (longer length) and 2 shorter length ones plus the a short set of rails and the Rosa ones being used on my Z Axis (700mm) was around €2500 or 3000. Not cheap but the 'list' price on a Bosch 45 Rexroth with rollerbearings and a set of carts is around €1K per set.
The Following User Says Thank You to Chaz For This Useful Post:
30-05-2017 #2
That seems reasonable I was thinking it would be even more! Amazing how being into cnc changes your perspective of reasonable lol.
So glad I only want to do aluminium and wood. This is definitely the most interesting (Read loony toons) cnc build I've ever seen if only for it's grandeur.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
30-05-2017 #3
30-05-2017 #4
Ok, cleaned up a bit, removed the reference table, mounted the main table and did a quick test fit of the Z Axis bottom part.
The naked machine
Some bits on it
Z axis, ballscrew is just 'hanging' onto the overhang, not mounted. The Z axis needs some of the holes to be drilled all the way through and I need to find the location of the bottom carts. I did not have the measurement at hand when I machined the holes on the larger mill. As these are not threaded, I have a bit of margin for error.
31-05-2017 #5http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The Following User Says Thank You to Desertboy For This Useful Post:
01-06-2017 #6
Can anyone recommend me a nice simple watercooling solution for the 4KW Spindle.
I had considered something like:-
6mm fish tank tubing (size to be confirmed)
Small fish tank pump
Some form of container that allows the heat to leave the cooling cylinder.
Ive seen some elegant solutions that use a CPU type cooler for a closed loop system, I am all ears ...
Something like this (With fans stuck on it) would work well
http://www.ebay.co.uk/itm/Baxi-105HE...UAAOSwA3dYPbSU
Simply splice the radiator into the return.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
There are currently 27 users browsing this thread. (0 members and 27 guests)
