Page 45 of 63 FirstFirst ... 35434445464755 ... LastLast
  1. #441
    If using R&P, yes spring load the pinion against the rack - this takes out 99% of the backlash, but also fit a stop to the motor/plate to stop it being able to disengage or jump the rack if overloaded, a jumping pinion will chew both rack and pinion instantly meaning an expensive fix, far better to stall the stepper.
    I use R&P on my plasma table and its been flawless so far.
  2. The Following User Says Thank You to Davek0974 For This Useful Post:
  3. #442
    Dave
    For twin screws you need Linuxcnc V 2.8 master if you want independent homing. I you want to reverse on of the motors then you can just swap the phases around on the motor.
    What version are you using?
    It's not Dave it's me ;) I'm using the beta I've enabled the master repositories so should be bang up to date, it's does read 2.8 something on boot.
    I was hoping it was just an option in the ini to invert them you can do it from the stepconf but that's no good for setting up dual ballscrews.
    I guess swap the wires around will be the easiest solution.
    My brother asked me what I want for Xmas was going to ask for a 3nm nema 23 which I'll fit to the gantry and swap the 2nm from the gantry to the Z.
  4. #443
    I was thinking a dual pinion setup to remove the backlash, if I build this I'll put servos on it.
    When the time is right I should come down and give you fusion 360 lessons and you can help me with my R&P ;)
    Ordered myself a new phone
    https://www.banggood.com/Elephone-S8...r_warehouse=HK
    Cheap Chinese of course have better things to spend money on.
  5. #444
    Sorry Me Can you post your ini and hal files and I will take a look, you can invert them in hal. I am In Spain again but back on Tuesday but I might be able to do it from here.
  7. #445
    Enjoy the sangria & sunshine ;)
  8. #446
    Got my MDF bed on now I need to make it a vac bed ;)
    I used an 18mm sheet
  9. #447
    Pics or it didnt happen :D
  10. #448
  11. #449
    Looks neat ;)
  12. #450
    Looks neat ;)
    It just fits and I mean just lol I had to tap it in the corners which is the fit I wanted was stressed about this cut as I had to outsource the cut and I knew it would be a bastard luckily I got a friendly a wood guy to help me out.
    As soon as you say i want 135.1cm *100cm people look at you funny lol.
