26-08-2018 #27
If you are making general hobby parts then all sorts of setups are required including vice work, plates clamped to the bed, set against dowel pins etc.
Also are you planning on using epoxy to level the bed? You can skim this with the router to get a surface which is parallel / matches your rails.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
